Search for tools and product advice,
Discuss Timer Switch on E7 system in the DIY Electrical Advice area at ElectriciansForums.net
JohnJP70
Hello all,
I hope you might be able to help me solve an issue.
I rent a flat with storage heaters and E7. The Timer Switch for the cheap periods has never worked, so in the past I've just had to move the sliders manually to use the heaters, but now even that doesn't work, as some electrical impulse slides them back again - thus, no heating!
In a way it's good news because there's obviously life in the system, but can anyone a) explain why this is suddenly happening and b) is there a way around it until a sparky comes and sorts it out?
Many thanks in advance,
John
Have you got a phot of the timer?
It sounds like the time is set wrong or the clock is slow and the OFF peg is resetting the manual override.
You may find that the timer for your(and other tenants) E7 supply are in the supply cupboard for the building.
Is there one? Have you had a look? If you can, send a photo.
I'm the tenant. As far as I know I'm the only flat in the building using E7. I'll look for the timing switch when I get home, nobody has found it yet!
Thanks both for being so helpful
John, if you are the tenant of this flat, would it not be better to contact the Landlord? it's his responsibility, and fiddling about with the controls of the E7, may get you in hot water with regards to your tenancy agreement.
Yes I'm talking to my landlord about this. The sliders are on a box next to the fuse box, one for each individual heater. There's nothing on the heaters themselves.
I wish it was as simple as 'just reporting it to my landlord'. We've had a succession of supposed experts not solve the issue, hence asking here.
Could always ask for rent rebate.
My focus is sorting the issue out, not alienating my landlady. Can we stick to that please
Not sure how you are alienating your landlord - you are paying for a service that she is not delivering
Who were these "experts" who have visited?
She needs a spark in that knows what he/shes doing, E7 isnt rocket science, any competant spark should be able to sort this out. Can you upload a pic or possibly email a photo to a mod to upload
Hi,i would ask the landperson,if you can source an expert,yourself,not that you should have to.
You are genuinely limited to what you can fiddle with,in an attempt to rectify this.
Some pictures or a more detailed description of the system,may allow us to work out the issue,and advise further. For instance,how you are billed for your two rates,would help.
Ok, the situation is now clearer. I have a 30 year old timer unit that is connected but defunct. An electrician came round, spotted the issue, and has since told my landlady it's a 2 day job to replace it - he has since disappeared.
Is it just me, or does that sound far-fetched?
@JohnJP70 ah. Do you obviously now know where the timer is!
Let’s see a picture of it and associated wiring. Then can give a better idea.
Pictures would be good, most new installs use a five wire electronic meter but older ones use a four wire plus a timer.
No wonder he hasn’t been back!
Seems these are an old and extinct system for ECONOMY 7 heating systems.
I’ve found s thread about these with links to instructions, but I think you’ll need an electrician who likes a challenge to rip it out and put something modern in its place.do report back with any progress!
This site won’t let me provide links to Screwfix Community forum. But if you go there, to the electrician forum, you’ll find it if you search for
electratech storage heater control panel”
There is no link. Just google
and you'll see the link to the screwfix discussion, also some other interesting stuff, like a user manual
http://pgbw.org.uk/electratech/Electratech Professional Manual.pdf
But yourlandlady should be getting a proper electrician in to sort out a solution. In case she hasn't noticed, its winter.
Yes. I have notified her, and have also made reference to the info you have passed on to me here - hopefully that will speed matters up. At least I can use the system manually...
Reply to Timer Switch on E7 system in the DIY Electrical Advice area at ElectriciansForums.net
I was looking for some advice on common wiring styles for stairwell delay lighting circuits. So I can figure out what has been done in the...
  • Locked
5K
Had a weird one tonight, with a new tenant who had a higher than expected first monthly bill. Studio flat with one storage heater and off peak...
K
I rent out a flat in a small west London block built in 1990s. 2 storage heaters installed around 2005 now have stuck or broken switches so I'm...
4K
Firstly i'll point out that i'm the property owner and the installer of the majority of the electrical fittings in the building, including Main &...
4K
