Discuss To tie wrap or not to tie wrap. That is the question in the UK Electrical Forum area at ElectriciansForums.net
I’m doing a 48way three phase board at work with 34 circuits. How to keep it tidy without tie wraps? Or is tie wraps the way to go
big boards like that, the only choices you have for a really neat job without spending days on it, tie wraps or if its big enough you can screw some slotted trunking down each side.
Are all the cables coming in top entry?
Start with the largest cables at the bottom and then cascade down to the smallest at the top..
Avoid RCBOs with functional earths, better still go for one of the new Schneider boards
Use tie wraps to form the wiring into place.
Remove when all testing is done, as long as you ran them in neat, they shouldn't move too much.
Pet peeve of mine is cable ties where they aren't needed. An if I find people tying cables together in trunking. Heads will role. Nothing worst than having to pull out a cable in trunking an finding its tied to all the others.
The old school sparks I have worked with would have lobbed their hammer at you if they saw you putting ties around cables in trunking
I have a similar amount of anger directed at whoever tapes up bunches of cables before pulling them down conduit.
makes it almost impossible to pull an extra one down after
At one of the theatres I work for every circuit has been individually cable tied together in the trunking every couple of metres using the cable ties that incorporate a label where the circuit number has been written.
So it is very easy to find the relevant singles in the trunking when making alterations, and not too bad to pull them out if you are moving the whole circuit. But trying to alter a lighting circuit is a nightmare, you pull the s/l and the strappers, perm live, neutral and earth all come with it.
Reply to To tie wrap or not to tie wrap. That is the question in the UK Electrical Forum area at ElectriciansForums.net
Hi Everyone, Sorry for all the questions. With he help of a friend, I recently installed some insulation into my mother's loft. Whilst adding...
Hello everyone. Budding DIY enthusiast fascinated with how things work - and, to a lesser degree, fixing things that are not working. I suppose my...
I'm in a questions asking mood tonight. I briefely looked at a job today and I need to recommend a board change but need to justify it. Firstly...
Re:Grid tied System. Could someone advise please on the following. I wish to install a 3 phase (input) Grid Tied system to my home (2 - 5kw). My...
Hello all! Newer house, original owner(Florida). no change to electrical system. Just found there was an outlet (GFCI) in the closet so I wanted...
