Search the forum,
Discuss Two fuseboard fitted with new installations - i need two certyficates ? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
P
poul
hi
just quick question, i have new installations, and i expect electricial for testing and give certyficate, but i have two fuseboard, i have one supplier head split for both so i need two separate certyficate or its possible put on test results from both for one certyficate ?
thanks
Just test the first board as you normally would, then put the second board on a continuation. The origin details will need to be worst case scenario so I would measure at both main switches etc and record your worst. There would have to be something amiss if you different results though.
Is this one home or 2 flats?
If its 1 home then one EIC and 2 x schedules, if its 2 flats, its 2 x EIC and 2 x notifications to LABC
Are you a registered sparky?
hi
i not yet registered, i am just pas 17th ed electrician, i do domestic installation and som of NICEIC Aprooved contractor certyfited my jobs, but now he go outside UK, so i just get other electrician, and he said i need 2 certyficates. this is two fuseboard for one big house, 1 is 10 way where is all socket, oven, undelfloor heating, and next one is just lights (5 circuits) + mains for smoke detector.
so, it's 1 installation with 2 CUs. that means 1 certificate, with a SOTR for each board.
Reply to Two fuseboard fitted with new installations - i need two certyficates ? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi everyone, I am new to photovoltaic system installation, can you guys give me some advice. Currently I plan to purchase a Maysun Solar 800W...
Hi everyone, after temporary removing a Sonoff that I've installed years ago to do some painting, I'm unable to get everything back to work. I've...
Hi Guys I've fitted a few emergency lighting circuits to both domestic and commercial installs before, I've come across one I can't get my head...
I've recently has an EICR (report attached) carried out on my two bed flat because I need to rent it out for a year. The electrician has come back...
