Search for tools and product advice,
Discuss Visonic wireless alarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
onions1066
Just looking for a bit of advise from any of the alarm guys. Went to look at a mates alarm today it is a visonic wireless version. The story behind what happened is the battery's ran low in a sensor the batterys were replaced but the lid want put back on properly. So numerous faults were relayed to the panel and it seems to of clogged the memory. I can do nothing with the alarm it just reads memory trouble. Has anyone come across these alarms or this fault who can give me any advice. Thanks in advance guys
Sent from my GT-I9505 using Tapatalk 4
Jamming suggests the panel is constantly picking up a signal, and hence thinks its being jammed.....suggest there is a cover off one or more of the detectors, once closed system should reset itself, within a few minutes.
Cheers tazz I'll go and have another look. The guy who installed it went to have a look and said the memory is jammed and requires a full new alarm install. I don't know much about wireless but sounds a bit far fetched.
Q:Display shows [SYSTEM JAMMED] – what should I do?
A:
This is an important feature as panels in a constant jamming mode can not hear other transmitters on the system which causes inactivity and testing problems. To fix this problem, check if there is anything around the panel that could be causing RF interferences, for example, baby monitor, WiFi transmitter, door bell etc. To eliminate anything within the home, if possible, turn off the main electricity supply.
From the visonic FAQ page
Reply to Visonic wireless alarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
OK, I'm still as green as a baby's nappy with all of this. I decided to change career and took a part-time night course (More on this later if...
16K
I am thinking of installing a wireless home alarm possibly texecom premium elite. But i would like to extend it to cover my van as well, when its...
V
Hi Guys, Have i been to a hum dinger of an installation today! Are we sitting comfortably then i'll begin. An electrician i was talking to in the...
V
Videodoctor
V
M
Peugeot 206 cc 2003 - The story so far...... whilst driving in the rain my wipers stopped working resulting in recovery back to my house with the...
8K
mrpinky
M
