Discuss Wall chaser recommendations in the Electrical Tools and Products area at ElectriciansForums.net
evening folks, looking for recommendations for a 240v wall chaser and extraction system.
id rather pay for quality to take the pain out of chasing and tidying up, ideally comment on chasers you actually use yourselves.
much appreciated Shane
If you are in this for the long haul and want to use it day in day out then Metabo
if it’s just for occasional usage I bought a second had sparky wall chaser and it’s ok for small jobs
no mate its long term, started on own 7 months ago so still buying start up gear. thanks for the recommendation
Miles tool & Machinery Centre have MFE40 chaser for ÂŁ344 ish delivered.
N&B Power tools have ASR 35M ACP extractor for ÂŁ410 delivered.
Prices include VAT and are for 240V tools.
Yup. Just bought the same kit. Make sure you get the triple blade, you don't even have to break out the middle of the channel. Check YouTube there are some good videos of it in action.
I have the MFE30 but that’s been replaced by the MFE40 now. I’d be going for that with the triple blade - which seems to have good reviews here.
A good dust extraction unit is just as important.
I only have the L class vac but it’s perfect for what i do, couldn’t justify the cost of the M
I have an old sparky twin disc attached to a Henry with electrical tape
been meaning to upgrade it for about 5 years but while it works can’t part with it
excellent ill get a look, thanks
As a few of the others have said, the metabo mfe40 is great. I cant compare it to others as I have only used this one. I use it with the triple blade Metabo MFE40 240V 240V 40mm 2x125mm Wall Chaser Kit - https://www.ffx.co.uk/product/Get/Metabo-Mfe40-240V-4061792154247-240V-40Mm-2X125Mm-Wall-Chaser-Kit.
The triple blade takes out the entire chase. Also, with the dust extraction attached it virtually all goes straight into the vacuum cleaner.
I use the nilfisk dust extractor from screwfix as the price was so much better. It works, although at times it get clogged up in the wall chaser. Takes seconds to unclog, but it does make me wonder if the more expensive metabo dust extractor would have been better.
I used the chaser once without the dust extractor attached just see see the difference. I won't be doing that again.
I pulled the trigger on the metabo mfe40 with the dust extractor a couple of weeks ago. Was umming and ahhing a bit because of the price but after the first use knew it was worth every penny. Did a couple of chases that would've taken the best part of an hour in a few minutes and there is literally no dust, that is if you remember to connect the nozzle to the chaser unlike I did the first time!
Yes, that's one of the features of the Metabo dust extractor that helped me decide, as it vibrates the filters when they get clogged up.
There seems to be very limited stock of those metabo wall chasers at the moment. I got mine little while ago and can't wait to use it. Its just laying in the garage looking pretty for now.
I got it from Festool discounted at Powertool-Supplies - https://www.powertool-supplies.co.uk
but not showing up now. I've only paid ÂŁ342 inc triple blade. If you not in rush may check their website from time to time.
I spent a few thousand over the christmas period on new tools and stuff. bought metabo chaser and dust vac.
Very happy with the metabo mfe40 and dust vac, it probably saved 2 days on a recent job with the amount of chasing that was involved. the triple blade is worth the ~ÂŁ85-90 cost. Dont set the blade too deep as that slows it down, but at 25/30mm deep it is brilliant. makes life so much easier, will pay for itself in no time.
Reply to Wall chaser recommendations in the Electrical Tools and Products area at ElectriciansForums.net
Hi all, Got an awkward bathroom fan installation in a downstairs flat, concrete ceilings and (some) walls. Bathroom is already fully tiled and...
I'm currently refurbishing a room and in the process adding some internal wall insulation. The wall has been stripped and my electrician has...
I seem to be getting more rewires than usual and am considering buying certain tools that aid rewires as they are bloody hard work. At present I...
10K
Hi, I'm having a new boiler fitted in a new location. I need to provide power for the boiler which I'm looking to do myself. Boiler: Ideal Logic...
