Discuss what is electricity rating for in the DIY Electrical Advice area at ElectriciansForums.net
Welcome to the forum mate.
Can you give an example?
What do you want the meter for? What circuit are you intending to use it on?
Hello
for example i have electricity meter that show rating
5-30Amp
can it pass or count less then 5amp
What is the meter used for and why do you wish to change the value?
The meter you show will probably be factory calibrated and will show how much energy passes through it during use, we need to know why you wish to change this value before advice is offered on the matter, altering the calibrated setup would mean the meter would not function as designed and you would end up with a readout that doesn't match actual energy consumed.
I don't know, but I imagine it will accurately record current in the 0 to 4.99A range too.
A quick spec look up tells me the upper figure is the current max, 30A in this case. The meter will likely lose accuracy and may be damaged by currents higher than this. The meter spec I read said the meter "shall take 120% of max current for 1 hour without damage". The lower figure is called basic current and the spec I read said the meter "shall record accurately at 0.2% of basic current". Your meter may have different specs, but it's probably similar. Hope that helps :)
Reply to what is electricity rating for in the DIY Electrical Advice area at ElectriciansForums.net
I have a question which is confusing me and I cannot find a definitive answer and I hope someone can help. So I have a PC and Monitor and I have...
Hello, I am seeing two mini split ACs with the same cooling capacity in two different company. Both 24000 BTU and Inverter. The first one said...
Hi all We are hoping to upgrade our oven. We currently have a single integrated oven and a separate induction hob. Each has its own red switch...
Hi all, Not sure if asking about rates is allowed, but I'm wondering what people's thoughts are on chargeable rates for PAT testing. Baring in...
