Discuss Wiring & fuses required for new Neff hob & double oven ? in the DIY Electrical Advice area at ElectriciansForums.net
S
st1300
Hi guys,
A little bit of advice would be most appreciated:
I have just purchased a Neff 4 ring ceramic electric hob with a total load rating of 6.6 KW &
Neff double built in electric stainless steel oven (going into tall cabinet) both oven consumption of 0.79 KW each with a total load rating of 5.7 KW.
What wiring & amp fuse/rcd will I require presumably both need hard wiring & what should I be expecting to pay an electrician to do the job ?
What you are asking is situation dependent and we have so little info on your existing install and the info required with your limited knowledge will be hard for you to forward so you will struggle for any real answer, I recommend you find local firms 2 or 3 and get a few free quotes. (post your location we may have a member close)
Welcome to the forum ...PS if your digging for an answer to do this yourself then you won't get one too many factors are involved and at the end of the day your family's safety isn't worth the cost cutting.
If not then we need you to give a full electrical detail of your incoming mains and its earthing plus your bonding, the consumer unit you have and available spare ways as well as distance and install methods, then we may be able to guide you.
Thanks I will gather more info.....rest assured I won't be trying it myself !
Thanks I will gather more info.....rest assured I won't be trying it myself ![/QUOTE]
Ok there is a cooler there hard wired into a cooker switch which then goes back to the electrical mains board to a 32amp rub (man's board changed to rub when house rewired in 2010
Ok there is a cooker there hard wired into a cooker switch which then goes back to the electrical mains board to a 32amp rcb (mains board changed to rcb when house rewired in 2010
then it should be a simple job to do if the hob and oven are both close to the cooker switch. i did send you a pm offering to quote.
Reply to Wiring & fuses required for new Neff hob & double oven ? in the DIY Electrical Advice area at ElectriciansForums.net
Hi all We are hoping to upgrade our oven. We currently have a single integrated oven and a separate induction hob. Each has its own red switch...
Hi all, looking for some clarification on MCB and cable sizes I need to run for a new kitchen. Cables will run through a combination of...
Hello I have two new appliances Electric oven rated at 3.95 KW Induction hob rated at 7.2 KW total of 11.15 KW Currently it is on its own...
4K
Hi, we are replacing our old hob and cooker and I need a bit of help, to make sure all is safe. This is the oven and hob specs: AEG IKB64401FB...
Hi all Some advice on this would be great. Due to wire a kitchen from scratch and in a pickle over the designing of the oven and hob circuits due...
