Discuss Proving Your Neutral Electrical Connections in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I rely on the following to prove my electrical connections:
  • Having a Torque Screwdriver for show and occasionally use it as the fancy takes me
    Votes: 0 0.0%
  • I am a 17 Day or electrical trainee, what is an R1 + Rn test anyway?
    Votes: 0 0.0%
  • Total voters
    31
There appears to be anecdotal evidence from recent threads and the interminable debate regarding BS 7671 Amd 3 and the non-combustible CU thing that Neutral connections are the source of many overheating incidents that in some cases lead to fires. There is nothing currently in BS 7671 or other Codes of Practice that require the integrity of the Line-Neutral circuit to be proven
- What is your experience?
- Do you carry out any tests to ensure that the joints that you produce are always 'sound'?
- Does your experience and 'Mk 1, Self-Calibrating' right or left wrist do the right job every time?
- Will you share your photos of the results of dry joint resistive heating and its aftermath if any?
Discuss!
Research regarding the causes of electrical fires; US source
http://www.interfire.org/features/electric_wiring_faults.asp
Well.... you could do an R2 + RN BUT if its slightly loose you may not see a different reading to R1 + R2 - but a few weeks down the line you may!!
So it might show up on an extremely diligent electrical inspection? ... but definitely not on most EIs and definitely on a 'drive-by shooting'!
The neutral bars that seem to be generic on some boards seem to have very tight threaded screws , so much that I have had to use a large flat driver to get them to tighten , if you use a torque driver it would be useless in this situation , you have to really pull them to check that the screw has properly held the wire , doing an e/loop or Rcd test would not always show the loose neutral, I am in favour of re checking all connections after the board has been in use and like to re check the following day when re wiring etc ...
Couldn't answer the poll because I do the Mark 1 right wrist thing,then I wiggle and jiggle,thats followed by a supplementary self torquing third twist with that Mark wrist thing again
me too and noticed that 2 people have voted this way HOW?
You are allowed to select more than one option ... I believe, at least that is how I set it up! How did you get to see the voting ... I can't!
only let me do one option!
to see who has voted just left click on any of the scores at the right hand side and all is revealed (did say a public vote)
tried that. takes me to photobucket asnd a load of spam.
A good few years ago I read a post on here from a wise old spark who said that, as the last person in the consumer unit, it's you responsibility to make sure EVERY connection is left secure. Since then that's what I've done, admittedly using the self-calibrating wrist method.
One of the options should be:
"when you have to open a CU do you check all the connections for tightness?"
Thanks for keeping that wisdom alive ...
M, I just wanted your confirmation that this is what you do ... I did not doubt it for 1 ns!
I have nothing against the self-calibrated wrist of a time-served spark, or a the 17 Day or Electrical Trainee who competently discharges their responsibilities in a professional manner! I have no time for anyone who does not act in a professional manner.
If I'm measuring a Zs, I'll usually do the Z(line) at the same time; it's an easy check that there's a decent neutral connection. It's just another button to push on the MFT if you've got three test leads connected already.
(BTW, what's the proper symbol for line impedance?)
Nowt in BS 7671 on the subject of the Line-Neutral impedance ... another sign in my book, that the regulations focus so much on the safety function of an installation so as to leave a gaping hole in the safety of the functional purpose of an installation, to distribute power!
I wrote something then edited it a few mins later then it come up I wasn't logged in so I just deleted it as couldn't be bothered to write it out again lol.
LMSO! I get pretty frustrated ... I have lost a number of well penned 'thoughts for the day'. I now copy the text to an iPad note if I get the ominous 'you do not have permission ... ' message!
Does this mean your MFT will allow you to do a Zs without a N connction? My Metrel won't
Lol yes It's very frustrating when it happens, I normally copy and then paste it when I log back in but It didn't seem to work that time.
Cannot comment on the Metrel
My Megger requires the N for the No-trip test (three lead test) on the Hi-current test the N and E leads are connected together (effectively a two lead test), for testing ZP-N the Hi-current test would suffice because this would not trip any RCD.
Yes, it only requires all three leads for the 'no trip' Zs. The full current Zs and the Z(line) tests only need two leads. However, I usually connect all three leads and do both Zs and Z(line) together.
Edit: Fluke 1652C
Reply to Proving Your Neutral Electrical Connections in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
G
I'm taking C&G 2377 22 next year probably around May ish My hunch is that asking some qualified electricians a few somewhat daft questions...
5K
goodconnection
G
E
I think I've Posted this before, but I've just updated it. Some of the sparks where I work still get a little confused of what the different areas...
78K
P
:there have been a few posts recently asking "Can I do a pir without being in a scheme" The simple answer is "YES" :Do I have to have my 2391 to...
14K
nottz_spark
N
P
Guys, The 2 bed flat I recently moved into is all electric. It has a Hyco Instaneous water heater (rated 12.8kW - 53A at 230v), a Shower...
4K
A
17K
amberleaf
A
