Discuss Bizarre Wiring And Readings Through Upstairs Windows in the UK Electrical Forum area at ElectriciansForums.net
The solution is to buy copious amounts of aluminium foil and put this on the walls behind the paper and paint. cover your window panes with the foil and it will protect you from the potentially harmful currents and signal waves. All just in case you are being monitored. If you have any foil left on the roll you can make a hat to wear when driving and out the house.
Could become a bonding issue , your need an electricians help !........copious amounts of aluminium foil and put this on the walls behind the paper and paint....
brilliant film.I know this is a silly movie, but it's got aliens (so maybe connected to the OP?) explosions and very big 16" guns that fired projectiles weighing a ton over 20 miles. And that track
Best bit is 4:30 ...
Reckon She has been abducted by the Aliens, or the lectric PoliceJesus 47 posts & still running, unusually the OP seems to have legged it. Either as said by vortigern earlier, it's a wind up. Or she's been carted off to the funny farm in a strait jacket.
Anyway we learned something new again today, There is someone out there crazier than us lot
QUOTE - [ Anyway we learned something new again today, There is someone out there crazier than us lot.
I resent that ascertion !
I secretly enjoyed Mr Smith's post.
I may be going across to the dark (and wet) side ...
Reply to Bizarre Wiring And Readings Through Upstairs Windows in the UK Electrical Forum area at ElectriciansForums.net
