- Sep 21, 2010
- 7,645
- 7,516
- 10,256,798
- United Kingdom
- Other
- If other, please explain
- Practicing electrician industrial, commercial and domestic.
I've never used NYY-J cable, interesting. Does it come up to BS standard for a general installation, lights, sockets, etc?I like NYY-J much easier than swa but the chances of getting the length you require instead of a drum is remote whereas swa you can often get a cut length.
I come across quite a bit of SY cable supplying 3 phase machines and external air con systems. I thought it was a bit of quick way of going about things, especially when not glanded correctly, as is usually the case....and have used it for feeding from panels or control units.
Is there not an argument for all the Y's being regarded as control rather than supply cables?
