leebut
Jun 5, 2013
147
63
103
Bury
Hi Guys
I'm not a Hager user so hence the question.
I've been asked to wire in lights and a fan etc for a bathroom for a mate of mine who's a bathroom installer, I've called at the house today to take a look so I can price the work, the existing consumer unit is a plastic board fitted out with NB range of breakers the board is nice and tidy inside and the install doesn't look that old so the customer isn't wanting to do a board change.
My question is do Hager do an RCBO that with straight swap the NB106 breaker there already same as the likes of Wylex etc if so do you have a model number?
regards
Lee
Thats the main reason I like Hager.
The recent low profile RCBO 6A is ADA306G
Hager gear is pretty much all compatible and back compatible. I tend to use it as my go to range for this precise reason, they also have and will be around for a long time, don't think they have changed much in the 20 odd years I have been an electrician!
Sy
Hi so does that mean the Hagers are all the same profile and I can use any Hager RCBO to replace the NB106 breaker
Even the logo lines up.
Bury
Hager NB106 Mcb change to RCBO
leebut,
leebut,
