- Dec 18, 2011
- 5,379
- 6,731
- 405,788
- United Kingdom
Hello all..
I have been asked to wire a relay into a FCU for a 3kW immersion.
The plan is for the customer to be able to access the immersion over WIFI.
The relay is a Shelly 1pm WIFI relay, 16A 110V - 240V.
I have not wired a relay before, hence asking on here.
The wiring diagrams on the MI (see pic) show it being used for a light, which will include a light switch. Therefore do I just make a link between the L and SW as seen in my written diagram? Do I need the link, or are these terminals purely so the light could still be used from the switch?
I don't see how I can wire this directly into the FCU for the immersion as the relay has a common neutral, I would therefore loose the double pole function of the FCU. So, I'm assuming the relay would get wired into the load cable coming from the FCU going to the immersion?
Thanks in advance.
Thanks in advance.
