- May 1, 2023
- 5
- 0
- 31
- United Kingdom
- Other
- If other, please explain
- race / rally car owner
I am rebuilding a track day E3O which had a M52B28 conversion ,the rev counter installed was a RMD brand which worked fine but I had to dismantle most of the wiring as the car had no dashboard at all just a alloy switch panel , of course after getting everything else working again in the replacement dash I cannot get the rev taco to work , I have scoured the net but no luck , I did see one post that you take the signal off a "blue " wire in the ECU but mine has no solid blue ?? , I was also told the black wire but after trying the 3 black I can find , nothing ?? I also tried taking off the crank sensor connection I first tried the black , nothing , then the red , which gave some intermittent reading on the gauge and caused it to swing full scale when I turned the engine off ??
the Wiring instructions that I got off the web are here
https://www.caigauge.com/documents//pdfs/pil019-367.pdf
Perhaps someone will be kind enough to advise me further ??
thanks in advance
Bryan
thanks in advance
Bryan
