How should we know whether it's any good, none of us have seen it or tried it out.
Why don't you ask your friend if it's any good, and if you trust them not to be stitching you up then buy it.
It does test RCDs. In general they are good testers.I can put some pictures up. It’s all working but the only setting it doesn’t do is phase rotation or RCD testing
I would not buy any Fluke 2nd hand tester until it is seen powering up and passing the self test.
(Anecdotal evidence suggests that they are more likely to have a hissy fit upon power-up than most other testers.)
I'm also curious....why do you want one? Didn't we have a long running thread where after about what felt like 18 months you bought an MFT, maybe a Kewtech if I remember?
For me an MFT is just a tool like a screwdriver is. Almost any brand calibrated tester will do the job.
Ah ok.I did buy one. I thought I would see if another trainee would indeed need one.
If that’s what he meant, I completely agree.If the RCD test setting doesn't work then it is not all working!
If that is the case then the decision is quite simple, it's broken, don't buy it.
This is the spec sheet on it and it’s not an open to do ramp testing;Get your mate to put it on FLeBay for spares and repairs / faulty for 60 quid.
Someone will but it
Could you clarify if it won't do RCD testing because of a fault.
I have a 1652b as a spare. It was my main tester for 13 years give or take.
They are bomb proof.
New Fluke leads would probably be more than the asking price for the tester.
This would be great for someone in a spot, as a spare or for a trainee.
