It’s not a fault it doesn’t do ramp testing or phase rotation. I’ve linked the spec sheet.
Many 2-pole testers show phase direction.
Personally, many months will go by without needing ramp testing, and an earth leakage clamp meter can fill in the blanks and is more convenient anyway.
If that Fluke tester is calibrated and you are satisfied it is in working order then its a very good price.
Test leads are consumables anyway. A shame it doesn't have it's case, as the Fluke cases are excellent!
I’ve a Martindale VT25 that does Phase Rotation. It’s a shame about the case. I’ve seen people use the Magnusson Organisers instead. The Fluke ones are very good. Needs a decent set of test leads as the Fluke ones are extortionately expensive.
I really wouldn't get hungup on phase rotation unless your work regularly requires it. It's not something I've ever used an MFT for, preferring instead to use a 2 pole tester. Occasionally a client wants to see this verified and we'll dig out a dedicated tester that shows all phases at the same time, but proves nothing more than a 2 pole tester.
I’ve found the fluke case for £35 and these leads:
Fluke/Amprobe TL165XA Lead kit. Compatible with 1650 and 1660 series Multifunction & Insulation Testers https://amzn.eu/d/boKad5Q
This is the Martindale ET4000 for £200. Just needs calibrating:
Is he having a bit of a clear out?
He has four lads working for him and he’s got 3 flukes and a Megger. The fluke and the Martindale are not getting used. He asked me would I be interested in either as a spare or to see if anyone I know was interested.
The Martindale needs calibrating but it’s all there and does seem a good buy at £200. But it’s whether the Fluke is better. As I do think it’s handy to have a spare tester. For unseen circumstances.
I’ve bought the Fluke. I shall let you all know what it’s like.
I was thinking of this as a case. But I’m not sure if it will fit in the middle:
RDB85
Trainee
Liverpool
Trainee Electrician
Fluke 1651B Bargain Price
Electrical Tools and Products
RDB85,
timhoward,
