why are you fitting RCD protection to air con units?
And why are you fitting two A/C units into a steel container in a Rotherham quarry that is only used for storing concrete samples - just curious lol.
6am in the wirral, after being across the mersey all night nicking cars?
That's fine, to be honest M&Q regs don't differ massively but there are subtilise differences.
With out out a detailed description of the install I can't say if it passes or fails.
Why not use singles?
bearing in mind this container has been completely lined out inside with cls timber and 18mm marine ply.then painted white so all the electrical installation is mounted on this.i used t+e as it what what I had on stock.
air con units in a steel shipping container.
BertUK,
BertUK,
