Discuss 2 way & intermediate pir is there such a beast in the Lighting Forum area at ElectriciansForums.net
the pict
Mentor
Usual thing, long hotel hall lights left on all day and night so control solution needed, is there products I can swap over from standard 2 way and inter switching, ceiling mounted preferred, I have had a trawl but cant see any at does not require a load of farkling around
P
If the hallway lights are going to be off you'll need to make sure every Room to hallway door is covered by sensors and the lights are triggered immediately.
I may be wrong, but I thought as a PIR will turn on then turn off again, there is no need to wire it like a conventional 2 way system. Just take a PL to each one and then a feed to the lights. If any activates then the lights come on. When they are all timed out the lights are off. Or am I over simplifying it?
You are correct the general switching can be removed but as Snowhead says all means of access would require coverage from the sensors.
the trouble having motions detectors on the ceiling are great.
but however if a long hall you say . I would change the lighting to led
because if the sensors are not set wright and you got a lot of traffic e.g.
customers it will go on and off like a space ship .
CP electronics make sensors with all these functions that can be programmed by their remote. We use them all the time for warehouse lighting. What's described in the above posts is called step down illuminance.
10a 230v PRESENCE DETECTOR RECESSED - https://www.mylights.co.uk/p/PIRANDPRESENCEDETECT/CP-Electronics-PIR-Presence-Detector-Direct-Dim-Time-Delay/EBDSPIR-DD
CPE COMPACT INFRARED PROGRAMMIMG HANDSET - https://www.mylights.co.uk/p/PIRANDPRESENCEDETECT/CP-Electronics-IR-Programming-Handset-For-Presence-Detectors/UHS5
Obviously the light fittings would have to be dimmable to be compatible.
Reply to 2 way & intermediate pir is there such a beast in the Lighting Forum area at ElectriciansForums.net
So I have the kitchen ceiling lights and worktop lights controlled by separate one way switches. The lights are constantly being left on...
Sorry for the long first post, I wanted to be as thorough as possible. On my landing I have a 2-way switch setup, one of which is 3-gang, one of...
Hi. First up, I am not a qualified electrician so this is a DIY project However, I am physicist by training with a specialism in...
8K
I've purchased Lepro 15m LED strip lights - product code PR410047-RGB-UK, and have fitted them at the top of the walls in my daughter's bedroom...
