Each fitting should be drawing around 0.15A running - allow maybe another 5mA for charging circuits on those with emergency lighting conversion.
20mA *34 fittings - 680mA or 6.8A allowing for variances, you shouldn't see more than 8A on the circuit at all.
Ohms law tells us that 8A at 230V nominal should be around 1.84kW. That's 1.8kW running - for an hour would be 1.8kW/h. You'd get to your figure fairly easy if the lighting is running say 14 hours a day - not unlikely in winter - and not unlikely if the dawn to dusk sensor isn't in a great daylight position. The official length of "daylight" is currently around 9 hours. That increases to around 16 mid July, and drops to a low of around 8 mid winter - end of Dec.
My guess, unlikely much is wrong at all, and figures as expected.....
