Discuss 63amp rcd in the Australia area at ElectriciansForums.net
S
StopTapBob
63 amp Rcd protecting 3 circuits 2 x 32 amp breakers and one 16 amp. Is it ok to add a 50 amp mcb for shower also. How do you calculate the maximum load on the Rcd ?
63a is what its rated at, hence your worry, it really depends on the actual loading on these circuits, also, why 50a for a shower?
if possible, to save uprating the 63A RCD to 100A, fit RCBO for the shower. that is if you have a CU capable of this.
If those breakers are all going on the same rcd then there is a very good chance that they are going to "cook" it, depending on what the real load of those other circuits is. A cooker and kitchen ring, along with that shower will be curtains for that rcd.
80A ones will give you more leeway and are a fairly common size depending on make eg WYLEX but larger ones in some makes can be a real pig to find, or they don't fit :(.
Edit : looks like we are not able to link to TLC now - that link should have taken you to an 80A 30mA rcd for £23 ex vat.
Reply to 63amp rcd in the Australia area at ElectriciansForums.net
Hi, I have lifetime experience (50+ years) in United States with basic knowledge of split phase 120/240 volts replacing wall switches and...
Hi All I'm new here. I have just finished my NVQ and waiting to do my AM2. I have a question on selectivity as it has always slightly confused me...
I’m running wires to the basement for future basement finishing. I’d like to add two circuits of outlets (one on the finished side and one on the...
Hi, I`m looking for an advice. I have an electric shower that I`m not using due to boiler changed to combi and added shower over bath feed by a...
The garage is 17 mtrs x 15 mtrs in the UKh The house has a 100 amp supply to the house consumer unit. The garage consumer unit is fed from a...
