Pete999
Supporter
Mar 14, 2013
25,716
18,746
18,688
79
Northampton
United Kingdom
Retired Electrician
Business Name
None
Back in the building boom, I worked for one of the large builders in the South West, throwing Houses and Apartments up at every opportunity,
We were expected to carcase a 3 be house in a day 1 sparky and 1 Apprentice, not much time for mentoring or tutelage there you would be right in thinking,
Anyway, my question, revolves around clipping cables along 1st floor and ground floor joists, the Manager of the Electrical Contracting Dept was a tight so and so probably brought on by being related to the main contractor, he wouldn't buy us cable clips, he told us to use off cut of T and E cut to suite and bunch all the cables together and suspend then by nailing the off cuts with plaster board nails, forming a sort of loop carrying these cables.
Rough you would rightly say, but when they could fire you for next to nothing we went along with it, surely this isn't done these days is it???
That's how we use to support the cables around the edges of the walls above the suspend ceiling when doing shop fitting but them jobs were ruff as F?%$
Would it solve the metal fixing over escape routes???????/
I've seen that a lot in houses when doing extensions etc.
I have used offcuts to secure T&E many times, but not in loops as you describe, I've used it like a strap to secure multiple T&Es going to a joint box.
I wonder if you bent the offcut right it could be a fire resistant support?
Reactions: DPG and Pete999
I discovered in my lads house, built circa 1980’s, that they used bent over nails to secure cables. Perhaps they knew what was coming in 2019 :-)
Reactions: DPG
Probable not, will need JW to do a mock up test to check and anyway its not just fire escapes now its all area :)
Big Bunches of cables held by off cut cable loops very common.
I remember helping on new builds when I was a kid and it was one of my jobs to follow the sparks round and bunch up pulled in cables then pop an off cut loop around them and nail to the joist.
I do seem to remember it became frowned upon due to cable grouping factors and schemes like the niceic insisted on individual clipped cables.
As for old bent over old cut nail for a cable clip is rough as ---- but again seen it loads of times in older houses
the rich girl wears a brassieire, the poor girl uses string. but Dinah uses nothing at all, she lets the buggers swing. that's the state of new builds now. all Dinah.
If you did your job right in the first place, you would use exactly the right length of cable. There wouldn’t be any offcuts;)
You clip the first cable, then tape all the rest to that, right?:)
This is a true story , I was on a massive new build in Wimbledon and was subby to the main electrician.
I started clipping cables as I always did roughly a hammer width between clips.
He went nuts saying what am Doing wasting all those clips and should only clip every 6 feet.
So I tried his method.
There was cables flapping and swinging everywhere but his argument was once the ceiling was up nobody was give a crap anyway.
He insisted on no capping just cables clipped to the walls and only 1 screw in a back box.
Nice...
Reactions: DPG
Tel, you constantly amaze me by bringng up stuff from the past...
If I remember correctly, that was a verse from
Dinah, Dinah, show us a leg
a yard above yer knee...
Happy days!
Our head girl, her name was Gwen...
she only liked it now and again...
and again and again and again and again
again and again and again...
Rich girls they wear rings of gold
poor girls, rings of brass...
but the only ring our Dinah knows
is the ring around her...aspidistra!
Reactions: Pete999
Happy days!
Sounds like my former head teachers guide for the school uniform, "skirts to be no lower than the knee...":blush:
Pete999
Supporter
Northampton
United Kingdom
Retired Electrician
Business Name
None
A blast from the past, at least my past.
Pete999,
Edtwozeronine,
