C
cyclistbruce
Hi,
I'm after some advice on motorbike electrics and Li-Ion batteries. I need to fit a 1.9a LED beacon to the rear of my motorbike so that it can be used for marshalling. I want it to be able to run off a seperate supply as you can't turn off the headlights and main battery drains quickly.
My idea was to get a 12v Li-ion battery and wire this to the LED light, with a seperate feed in from the alternator. So that (in theory) the alternator will run the Light and charge the battery, which can then power the light when the engines not running.
Would there be any issues with this, particuarly with the charging of the battery, am I likely to knacker it as theres no cut off?
Cheers in advance.
Cheers in advance.
