Discuss Another post from the American Forum that you Might Enjoy. in the UK Electrical Forum area at ElectriciansForums.net
Santa
Note that this is in no way an electrician's forum:
How many feet can you run wire from electric meter?
Concerned about voltage drop. And question might need to be, how many feet of electrical wire can I run from the transformer. I will give the details. Underground transformer is located on 42 acres in CO. Electric meter is located on a pole about 30' from it with 200 amp service.
AIUI, I believe it is 5% that some electricians consider the maximum voltage drop you want to experience and still not cause problems for electrical devices and appliances which may not have them run properly, if at all, and if they do, could still lead to them wearing out prematurely. Have welders, plasma cutter, and air compressor that I'd like to keep for a long time and don't want to make a mistake with the voltage.
For national code standards, does it list what gauge wire for a 200 amp box, and how many feet from meter would you estimate to still keep me under 5% voltage drop, if that is indeed the figure used? A ball park figure would be fine for now.
I want to move my cabin and building to a new location and was hoping for a better site without having to move transformer because that would be even more costly, especially since it's on the steep side of a mountain.
Read on for the advice he got: h ttps://boards.straightdope.c om/sdmb/showthread.php?t=860809
ain't them septics heard of reducing lugs?
straight dope alright! Id like to know what kind dope those dopes are smokin?
while some of the info is good there are a lot chiming in that should not be there
In the interest of world peace I've changed the link in your post to one that's not clickable by adding a couple of spaces in it. From past experience crosslinking between forums and debating the merits of their threads can cause animosity and start problems.
Reply to Another post from the American Forum that you Might Enjoy. in the UK Electrical Forum area at ElectriciansForums.net
hello. i need to run power to a cabin that is 350 feet from the service pole in our driveway. the problem is voltage drop. the service pole is 150...
Hello, I live in Mexico, where I have a small, un-official trailer park on my property. The property is serviced by my privately owned, 650amp...
When I joined this forum a decade or so back, there was a discussion going on about a welder that was connected with a 3-core cable to L1, L2 and...
  • Locked
5K
Hello, this is my first post here. I have a little experience with most types of household wiring through a decade of DIY remodeling, and...
