Discuss baumatic extractor hood faulty in the Australia area at ElectriciansForums.net
my daughter just bought a kitchen from a kitchen company thats closing down.
they included a baumatic BT066ME extractor hood but nothing happens when i turn it on?
theres power going through to the connector blocks then nowhere else,
on the switches are extra terminals but i dont want to move wires about and damage the unit.
is it possible the power light is a type of fuse?
if yes what amp will it be
the light is generally just a neon. does this come on when you power the unit up?
If it looks like a fuse it's probably a neon lamp in which case it's only an indicator not a protective device.
Easy way to tell is if it'swired with a live on one side and a neutral on the other it's not a fuse.A fuse will always have a live in and a live out.
when you say there is power to it, how are you measuring that. of using a voltstick or ( perish the thought ) a neon driver, it could be trhat the neutral is not present.
il check the current to the light tomorrow as im at home now and daughter at work. but theres power to the connector bloak but no power to the hood lamps or motor
so, if you have a L and N, and the neon doesn't light. then the fault has to be before the neon ( assuming the neon itself is good.). suspect connection/s, possible screw clamped on insulation.
I'm not trying to insult your intelligence so please don't take this the wrong way. Did you check the installation manual? There's often packing pieces and sometimes they tape or otherwise disable the safety switch if it has one.
no offence taken, theres no sign of any safety switch that ive seen apart from the one that when you remove the filter cover, it disables the hood, which is inplace when i tried it
Are you saying you've got power to 1 side of the mains connector but nothing out of it ? or have you actually got power going to the switch bank ?
Reply to baumatic extractor hood faulty in the Australia area at ElectriciansForums.net
Hi all, Disclaimer: I'm not an electrician and have very basic knowledge of electrical installation. We've been putting in a new kitchen into an...
My bathroom light went last week. I believe it's a "2D" bulb - the full model number on the bulb is F28W2D/835. The bulb had gone black at one...
Back home from Aberdeen. Nice little job. Parents of my daughters friend have bought a flat up there for them to move into next year... both at...
So this is a long one.. The other night my dehumidifier turned on and suddenly everything in 2/3rds of the house began cycling on/off and the...
  • Locked
Hi, we need some advice on our scenario with regards to our rewire plan. I will get this out of the way first... We are planning to put the house...
5K
