Search the forum,
Discuss Can you use a light switch to operate a socket in the DIY Electrical Advice area at ElectriciansForums.net
You said you wired it through the wall to a socket?
H
I'll ask once more, is the red line connected direct into a 13A socket with no fuse protection. It may help if your replies were more frequent than once a day.
Hi sorry I’m working at the moment and it’s a bit difficult to get time to respond. But the answer is yes the socket is on the ground floor socket ring so is protected by the fuse box
So your cable is connected direct to this socket without suitable fusing apart from at the fuse box which is probably 30/32A. Can you show a picture of the socket you have connected to.
Reactions: DPG
Hi this is the one we connected it to, it’s just a standard twin socket. I was told with it being on the main fuse board and the socket I’m using for the lights being fused and everything being low voltage, it would be ok
You appear to have a multiple outlet spur from the socket which isn't permitted unless it has been given circuit protection and your grasp of the correct terminology makes it difficult to decide. I would strongly recommend and although this may be difficult at present you find an electrician.
Reactions: DPG
Reply to Can you use a light switch to operate a socket in the DIY Electrical Advice area at ElectriciansForums.net
Hi I want to add a light to my attic. There is a single switch on the landing that I want to change to a double switch and then use it to still...
DIY'er question: I have a singe switched fused spur above my kitchen counter, providing power to an undercounter fridge socket beneath it. The...
I'm moving a socket installed on a lighting circuit (installed by previous owner who was a professional electrician so I assume he knew what he...
Hi all, I am planning to install wall lights such as these ones (LAP Bronx Outdoor Up & Down Wall Light Black - Screwfix -...
Hi, I have lifetime experience (50+ years) in United States with basic knowledge of split phase 120/240 volts replacing wall switches and...
