Discuss Cat 6 installation in the Computer and Networking Forum area at ElectriciansForums.net
E
euroman
I have found that Cat6 outlets from a major UK manufacturer fail testing with installed cable lengths under 30metres.
Does anyone have a solution please?
I am not familiar with that tester, so do not know what functions it gives you. Does the meter not tell you what it has failed on? (i.e. X talk), and where along its length it has failed (primary or secondary @ X metres)
Are the patch panels and IDCs Cat6? And are both ends punched down to TIA 568(B)?
It all passes cat 5e so it's not a wiring issue. Fails next at cat6. I have now changed out the euro modules for some manufactured by a networking company not an electrical accessory manufacturer and the system passes easily! There is an obvious lesson here! Thanks!
What modules did you end up using and which company did you use? Ill be installing cat6 in my house so any advice would be appreciated.
Phill
I got mine from AX in Horsham, the ones which failed were from (probably) the UK's largest accessory supplier. Hope that helps!
Reply to Cat 6 installation in the Computer and Networking Forum area at ElectriciansForums.net
Hi all My Fluke tester failed on one test today while having it's annual calibration, the continuity resistance test current. Test Current -...
Private tenant since 2011. First ever eicr February 23 informed via text it failed by text from electric secretary arranging appointment for...
A recent thread on the suitability of a cable supplied preinstalled on a manufactured floodlight/pump had me wondering a few things. Over the...
Hi guys, Had an issue at a recent survey where doing a quick check and found we had pme with a reading of 0.44 ohms. Called the network and they...
I have a towel dryer on an interior wall in my bathroom, wired off the last stop in my loop of bathroom outlets. This thing has been installed...
