A
Ampo
Hi all, I've just been to a flat with the old double stack mem cu which includes an old 63 a contactor for the storage heaters. Looks like contractor is getting very warm over time and the board could do with an upgrade. Anyone had to do similar and if so can recommend a good brand? I'm guessing these days the only way is to get a din mounted electronic contactor? Looks like it has a separate 1.5 armoured coming into cu with the tails, one leg to contactor and other to a 6a mcb so this must be being used as the switch line via a timer in the meter cupboard somewhere (which I'll have to find to kill mains tails). Just wondering if anyone knows of a good board for it. Single or double stack with at least 14 ways plus contactor. Also if intriloducing rcd protection has any one had issues with storage heaters? Couldent get in the meter cupboard today but from memory am I correct in thinking you can override the timer at meter for testing purposes on the off peak side? Any help appreciated
