Discuss DALI Control systems - Do i need different drivers? in the Lighting Forum area at ElectriciansForums.net
M
mungo2007
I have a project in a hotel that has a DALI control system
We are supplying LED downlights that are dimmable on the DALI protocol but they also want other lighting ground lights and wall lights that do not need to be dimmed.
Question is will they still work on the standard LED drivers or do these need to be DALI as well even if they are not being dimmed?
Any help appreciated
So do you want the DALI system to switch the other lights together with the LED downlights or can they be completely separate?
Either way you can get a DALI switching unit to switch whatever kind of load you want, it just makes things a bit more complicated.
It will be separate downlights in the hotel interior areas, but they also want the ground lights and floodlights on the DALI system but just standard switching, so totally separate circuit.
So would you advise DALI drivers on the exterior non dimmable lighting as well?
Reply to DALI Control systems - Do i need different drivers? in the Lighting Forum area at ElectriciansForums.net
We are in the process of renovating our house, and would like to setup led strip-lighting throughout. of the options, this seems most attractive...
I've been asked to quote for track lighting replacement in a London art gallery that's suffered extensive water damage from the floor above...
Hey folks, i work for a relatively small company, but we are doing some big jobs. And right our headache is taking over outdoor lighting...
I am currently looking to add 12v led cob strip lights to my mother's kitchen but confused what I need. There are currently mains wires under the...
Hey, with regards to DALI Emergency Lighting Automated testing via a control system, does anyone know how best to overcome a fitting that is...
