Deleted member 93172
Just a quickie, if the cut out fuse and head is rated at 63amp can you still use 16mm tails for a 6way board. The reason for asking is, I have to change a board in a old flush internal metal cabinet and there is next to no room inside due to the meter and cut out taking up most of the space, its probably possible to use 25mm with a bit of swearing and grunting but it won't look nice.
what is your loading for the said board ?
16mm tails loading 87 amps
25mm = 114amps
you do the maths !
Hi Buzz, the max for a 60amp fuse is 15kva, the board is only supplying 2 x rings 2 x lights and 1 shower with diversity, I have just got so used to putting 25mm in not to sure if it is a must to not to use 16mm, you can,t get a bigger board in the cabinet.
16mm is great to work with, just like a piece of string.:)
  • Funny
Reactions: buzzlightyear
Why not use a skeleton board as these are actually designed to fit into the units? I hate seeing standard boards bodged into mantel units.
Reactions: Dave OCD
Hi Lee totally agree, that's why I am putting in the Wylex FALNH806, the reason of asking was that the meter and cut out are taking up most of the room in the cabinet, so 25mm tails make life a bit awkward.
Distribution board tails
Deleted member 93172,
Nigel,
