Discuss Do I need to change to an 18th edition board when rewiring a house? in the UK Electrical Forum area at ElectriciansForums.net
I would not call it a complete rewire as we are reusing some of the original switches and sockets.
Ok then, so it's not a full re-wire. That is ok.
Personally I would go with all new sockets and light switches, that means these items will fall under the warranty if any of these goes faulty.
If an original socket/switches goes faulty then you will get charged for fixing it. It's not really worth it.
Of course, the consumer unit will not be changed so any faults on this are not covered by the warranty also.
You could always ask the electrician to leave a bit of extra cable in the circuits if you plan to change the CU in the near future.
I think it's impossible to give an answer without fully seeing and testing the existing consumer unit. It may have the knockouts taken out in the top (so will not meet IP4x), it may have other holes in it so the IP requirement may not be met there. Inside it may have damage or just bits that are poor and need replacing. I could go on and on.
I think it's ok to tell @jazztastical that he doesn't strictly have to have a new board with a rewire, but unless we are there we cant say that that particular board is ok to keep (or even the MCB's or RCD's as we haven't tested them and the on site electrician will have done).
I think you should get some other quotes and then choose between them, if they all say you need a new board then you need a new board. If they say you don't then you don't.
I wouldn’t reuse accessories either. Those are he parts that wear out, the cables could be perfectly ok, and only need a partial rewire.
As for the CU, @happyhippydad makes a good point about other holes that may be on faces we don’t see.
Even reusing the breakers in the board and replacing the shell may give problems.
The electrician will just be covering his own back by replacing all
Re-using the existing sockets. Mmmm, you don't by any chance want white screws fitting do you?
And that's why I put "if the existing board is still suitable for use" in my post to the OP.
Hi All. Thank you all for the information and opinions. I really would change the CU in an ideal world and I do see everyone's point about warranting work with mixed gear being an issue. All the switches, sockets and fixtures in the house are pretty new and good (never any issues with tripping, and the only real reason for the rewire is the mix of cables and JBs all around the ceilings, not to mention the dead wires running nowhere which makes this job require all new cables running. If there is some money left from this project I will change the CU. Thank you again
As others have said, having RCBOs would bring added benefit over a dual RCD board.
With regards to the price, £600 would be a reasonable price for the job of replacing a consuner unit if no other work was to be carried out. But all of the testing work will have to be done anyway if all the circuits are to be rewired, and if he is replacing all the cabling back to the CU then most of the labour involved is already covered by the rewiring. So in theory you should be able to get the CU done for less than half that. But it maybe that the job as a whole has been priced to take that in to account. But as others have said, get a few quotes
[automerge]1571235048[/automerge]
Actually maybe under half that was a little bit optomistic for an RCBO board if you have a lot of circuits but certainly less than 600.
Ok, is replacing just the cable and sockets classed as 'a new circuit' so building control has to be notified or it it an 'alteration to an existing circuit' ?
Reply to Do I need to change to an 18th edition board when rewiring a house? in the UK Electrical Forum area at ElectriciansForums.net
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
Hi all, I am looking for some advice regarding old rewireable (3036) fuse boards in regards to additions and alterations. I am an electrician and...
4K
Hi, I’d appreciate views on the fuse board. https://ibb.co/xj0BtZt It’s been completely rewired and I’m unhappy with the quality. I’ve...
14K
Got my 18th Ed certificate late last year, now doing 2391. Obviously Amendment 2 has come out since then, and I see these courses available to...
8K
