Discuss Doubling up meter tails in the UK Electrical Forum area at ElectriciansForums.net
Just wondering what the regulations are on doubling up meter tails?
My girlfriends dad wants to convert the garage into a 'granny flat', and I plan on doubling up the connections in the meter to take a new 16mm supply to the garage. Opinions?
No, just no!
Henleys are the way forward on this.
However, before going down the route of doing anything with the tails you should be asking how much extra load will this "granny flat" be putting on the existing installation. My guess is that it won't be very much so why not take a look at altering the existing circuits before getting into something that, with all due respect, you don't appear to have much idea of.
The reasons I say that are how big do you think the terminals are on this meter that you should not even be thinking about touching because it isn't your toy to play with and how many 16mm cables do you think you can cram in there without giving some of them a haircut which is something you should never even think about considering
Cut seals? god no :coolgleamA: . I'm probably going to instal henley blocks to be honest. The existing house already has an electric shower and cooker. And this new flat is also going to have an electric shower. Oh and there's going to be a hot tub installed in the garden. I know, tell me about it. So this is why Im running a new supply in.
Think you need special permission for it as so many people were doing it badly and renting them out.
Maybe it's a London thing ,maybe I'm wrong ( as usually )
forgive me me for saying this but you are not running in a new supply!
Reply to Doubling up meter tails in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Customer has an extension and this compromises existing meter position, DNO is extending incomer and putting meter box on a different...
Quick question. I want to put an isolating 2p switch on my incoming supply from the meter to the board. I want this to allow easier board changes...
Hi everyone, a landlord is converting a house into two flats and wants a separate consumer unit for both flats upstairs and downstairs. He also...
Hi, I was hoping someone with a little more insight might be able to shed some light on a potential issue I have, as I can't seem to find another...
7K
On a new build site how/ why are people getting away with installing meter tails over 3metres in length and behind dot and dabbed walls with no...
