Discuss Doubling up meter tails in the UK Electrical Forum area at ElectriciansForums.net
No, just no!Just wondering what the regulations are on doubling up meter tails?
My girlfriends dad wants to convert the garage into a 'granny flat', and I plan on doubling up the connections in the meter to take a new 16mm supply to the garage. Opinions?
Are you really planning to cut the seals on the meter?
depends on the house, if there is a bedroom above it then it doesn take much to convert oneHmm I thought that you couldn't change garages into living quarters
Incorrect but you have to remove the hoists and spray booths first.Hmm I thought that you couldn't change garages into living quarters
whats wrong with stringing a hammock across the hoists?Incorrect but you have to remove the hoists and spray booths first.
Would you want your granny messing with 3 phases? Or maybe you just don't care.whats wrong with stringing a hammock across the hoists?
I would remove the cable first mateWould you want your granny messing with 3 phases? Or maybe you just don't care.
GASP! And leave a 10mm wide hole with access to a live terminal? You sir are a monsterI would remove the cable first mate
Cut seals? god no :coolgleamA: . I'm probably going to instal henley blocks to be honest. The existing house already has an electric shower and cooker. And this new flat is also going to have an electric shower. Oh and there's going to be a hot tub installed in the garden. I know, tell me about it. So this is why Im running a new supply in.
Reply to Doubling up meter tails in the UK Electrical Forum area at ElectriciansForums.net
