Discuss Electric boiler installation in the DIY Electrical Advice area at ElectriciansForums.net
Hi,
I am installing a 12kw instantaneous water heater in an outbuilding which currently has a small water boiler with electricity and water in/out already connected so I thought it should just be an easy switch over.
The new boiler has arrived and has a much thicker cable (10mm2) and I was wondering if I could still use the same switch to install this?
TL;DR
Can I use the new thick electric cable with the same switch?
@James Sorry a follow up question, would an electrician be able to connect to a closeby closed socket (live cables from mains behind), or would it need to be wired back to the main board?
You cannot wire a 12kw boiler to a 13A socket! See post #2. I would recommend getting an electrician involved.
It is impossible to tell.
you really need a visit from an electrician to quote this job.
Reply to Electric boiler installation in the DIY Electrical Advice area at ElectriciansForums.net
Hi, I'm having a new boiler fitted in a new location. I need to provide power for the boiler which I'm looking to do myself. Boiler: Ideal Logic...
Hi, I have lifetime experience (50+ years) in United States with basic knowledge of split phase 120/240 volts replacing wall switches and...
As a young man, I was an electrician, but now I'm getting on, I am strictly DIY. I used to have a cheap old 900W petrol generator connected to a...
Good evening, I have recently moved into a new home and I am having problems with the MCB/RCD tripping (Mem M6 Type 3 - 30mA). It intermittently...
Hi, I'm interested in a house built around the 1980's in Northern Ireland. I took a few photos of the consumer unit etc. which is situated in the...
