Discuss Feeding other rooms with bathroom outlet circuit in the UK Electrical Forum area at ElectriciansForums.net
DaveBeal
My wife wants me to add an outlet in a large closet. It would be easy to feed the outlet from a bathroom outlet that is on the other side of the wall. However, I've read that the US electrical code does not allow connecting outlets in other rooms to a circuit that feeds bathroom outlets. Why? I don't see a safety issue. Is just to prevent blowing the breaker from excessive load? Thanks!
My friend go ahead and add a receptacle which is not going to hurt nothing and if it gets it’s power from the bathroom it is even going to be GFCI protected.
Reply to Feeding other rooms with bathroom outlet circuit in the UK Electrical Forum area at ElectriciansForums.net
Mobile home outdoor power supply is a pedestal that power to the mobile home plugs in much like an RV. The main power supply into the mobile home...
Hi all, Got an awkward bathroom fan installation in a downstairs flat, concrete ceilings and (some) walls. Bathroom is already fully tiled and...
I may have posted this before but not sure if it made it in. I want to install an EV Charger in my garage. The panel is two stories up and the...
Hi, I have lifetime experience (50+ years) in United States with basic knowledge of split phase 120/240 volts replacing wall switches and...
I have a main panel beside my meter on the house built in 1987. Then a 4 wire feed into a 200 amp panel on an inside wall of my basement. All of...
