- Dec 3, 2013
- 156
- 26
- 103
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- DIY or Homeowner (Perhaps seeking pro advice, or an electrician)
Hi,
I need to replace some of the wires to/from the electric fence energiser. The existing wires look to be normal PVC insulated wire like you'd use in auto electrics or inside a piece of equipment. Over a few years the insulation has faded and hardened so the wires are now quite brittle. The wires go to and from a solar panel (around 500mA @ 14V), to the earth stake and also for the output to the fence (high voltage). The wire would have to suit normal auto electric normal crimp connectors so I can put the correct terminals on, and obviously needs to be suitable for outdoor use.
I was thinking of using the sort of silicon insulated extra flexible wire used for test leads, does anyone have any comments or alternative suggestions?
Thanks, Tony S
Thanks, Tony S
