Discuss Form filling primary over current protective device in the UK Electrical Forum area at ElectriciansForums.net
S
schoe
On the main over current protective device I'm looking at it states 100 amp 1.3/16 DIA does anyone no what type and Bsen num it is as I can't see it in the regs.
Thanks Chris
Whoever put that made the best of the info they could determine... they could probably see the rating but no other info... so they measured the diameter at one and 3/16 inches with the intention of looking it up later..
Which would make it a BS1361 type IIb
Simon.
Reply to Form filling primary over current protective device in the UK Electrical Forum area at ElectriciansForums.net
Hi, I have a book on domestic wiring which says that everywhere there is a change in current carrying capacity along a circuit there must be some...
wiring a 480 volt 3 phase 114 amp generator to run 2 machines. Both machine nameplate 480 v 3 phase 50 FLA. What size wire and over current...
Hi, I was hoping someone with a little more insight might be able to shed some light on a potential issue I have, as I can't seem to find another...
7K
My understanding is that a SMPS does not separate, like a SELV transformer, the secondary from the primary. Therefore presumably the equipment...
