Discuss honeywell 8ep3p6a help thanks. in the UK Electrical Forum area at ElectriciansForums.net
J
jaosn
1st post super site. thanks for any one who can help with the 3 question on this x panel ( nightmare im having )
hello i got the honeywell 8ep36a there was a post last year i tryed before posting here of mod Tazz .
over the spanner double lock think .
i press p 9999 pressed number 2 set alarm of .
try again power and green lock and padded lock stays on .
led lit on panel are power/ lock and spanner green
2nd user can i change what is the code de.key ?? 0123?? (( unsure of the temp code if there was/or is 1 set in backup ))
last have set door to ding dong = but the red led stays on puzzled why press x clears unsure if i done somethink .
ps the manual is hard to under so in steps if possible thanks all .
Is this an Accenta panel..?, the 9999 code is for programming only...0123 is the default user code. red spanner led indicates tamper fault, either bell box cover or control panel cover on fitted.
i tryed again .
p = 1-8 red . then 9999 then sos .
the panel and bell-box have not been open seal on both .
any code or how do clear?? thanks for the reply :) .
so i use my code example..
p 2468 then xx xx ?? to reset the tamper spanner . sorry for been a pain .
friend as check box the sealer is still on screw on bell + box no on as removed it .
thanks for updating
Reply to honeywell 8ep3p6a help thanks. in the UK Electrical Forum area at ElectriciansForums.net
Im trying to make a Star Wars Prop for a course project where the dealine is comming up very fast in days and I need to do the report so really...
Background Two weeks ago, lightning struck a tree in our yard. Many circuits tripped and several electronic devices failed. There was a strong...
I thought that I posted this in the DIY part of the forum but I believe I did not. I am sorry about that. I put in a 10' x 20' metal shed about...
Hi all, total newbie to the forum. I sincerely hope that those in the know-how would be able to assist me. On my semi-detached house we have an...
Hey everyone - new to this thread so thanks for having me. I have an issue with my DC power in a small truck camper. I have 3 accessories plugged...
