Discuss I am allowed to replace the 2.5mm wire from a radial circuit to 4mm and the 16Amp MCB for a 32Amp in the DIY Electrical Advice area at ElectriciansForums.net
vadiro
Could you tell me please if I am allowed in England to replace by myself the 2.5mm cable from a radial circuit to 4mm and the 16Amp MCB it has now for a 32Amp?
It's a tough one... if I was being super cautious I would suggest this is not maintenance due to the fact it's a new cable and a new protective device which would imply it's the installation of a new circuit which would require an electrical installation certificate and a building control notification.
Plus, as you're a DIYer... how are you going to test to make sure it's safe?
Hi, thanks for the answer. My plan was to use a socket tester which is looking for continuity and polarity.
  • Optimistic
Reactions: DPG
That is a bit like kicking a car tyre to prove the worthiness of the vehicle. It needs testing, certifying and notification to Building Control.
Reply to I am allowed to replace the 2.5mm wire from a radial circuit to 4mm and the 16Amp MCB for a 32Amp in the DIY Electrical Advice area at ElectriciansForums.net
Hi guys, I have supplied my Shed with a 6mm SWA cable into a nice consumer unit. In there I have a 6Amp MCB for the lights and a 16 A supplying a...
Hi all, DIY'er here looking for a bit of advice so please go easy on me. In my dining room there is an existing single pendant and i would like...
We have a room in the house that was the kitchen. That has been relocated to a different area, so the old kitchen has been sold off and the room...
I'm in the process of renovating a house. As I go through room by room I am removing old plaster and as the cables are exposed at this point I...
Good evening all, I’m currently part way through my apprenticeship and we are working on IB, IN, IZ and IT and volt drop today. And it got me...
