Discuss Max Demand Blown Out of the Window!! in the Australia area at ElectriciansForums.net
C
Crashman
I'm working on a house that has no gas or oil, and it would not be easy to get bottled gas to it.
So here is my problem, the client wants everything electric.
So in his ideal world that would be:
2 x 9.6kW Instant water heaters
1 x Reasonable electric shower, say 8.5kW
1 x electric hob
1 x electric oven
and probably 5 x 2 or 3kW convector heaters.
Plus rings and lighting for a 3 bed house.
At the moment there is only a pretty dodgy 60A supply that will need upgrading even if it was to remain at 60A just because of the state of it.
The way I see it, which ever way you try and apply diversity you don't come anywhere close to getting under 60A!!
Does anyone have any bright ideas? Other than to walk away from the job!!
My knowledge of 3 phase is fairly limited, but I believe it could handle the required loadings if the house was to have it installed, but it it a realistic option in a domestic setting??
Rob
might be cheaper to fit storage heaters and get duel tariff meter as oppose to supply upgrade, its throwing money down the drain heating up the house during the day, although they might not be everyones first choice you dont seem to have alot of options and with energy prices rising the savings will more or less pay for the job over a couple of years.
Has you customer considered one of these......
Amptec
No they haven't. Will Look into it further and see if it could work. Thanks.
Yeah, I have thought about that, but to make the challenge a bit harder the place floods on a fairly regular basis, so all electrics need to be at least 1200mm of the floor. Not ideal for storage heaters!! There is going to be at least one, possibly 2 wood burners in the property, so there will be some heat not supplied be electricity!
Thanks for your thoughts.
Jeese ..... not the most cost effective house, sky high leccy bill and flood damage to boot :oops:
Reply to Max Demand Blown Out of the Window!! in the Australia area at ElectriciansForums.net
So, the actual job is on a farm. I think I'll keep things simple at the moment and just ask about voltage drop. I'll come on to earthing and...
About 15 years ago, after having had a modern consumer unit fitted, and prompted by our electrician, I asked my then energy supplier (Tonik) if...
5K
This isn't sitting right with me. So if I rock up at a house with a 60A suppliers fuse, it has a dear old Wylex with 1 RFC 30A (no diversity) 1...
Hello, this is my first post here. I have a little experience with most types of household wiring through a decade of DIY remodeling, and...
The garage is 17 mtrs x 15 mtrs in the UKh The house has a 100 amp supply to the house consumer unit. The garage consumer unit is fed from a...
