Discuss mem 2000 AD consumer box, rcd for an 8.5 kw shower? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
hi my name is Gerry and i am putting together the parts required to fit my new shower which is a Triton 8.5 kw electric shower my consumer box is a MEM 2000 AD and i am not sure which RCD to purchase my friend is a sparky and is on holiday in Spain at the moment and i would like to have everything ready for him fit when he returns as he is doing me a favor, could somebody please advise me on the correct one to purchase, and also if possible as i am interested the formula used to work this out, regards Gerry..
Drop him an email mate, he can pick it up when he gets home and you can go to the wholesalers.
I'm sure your sparky friend would prefer to be involved so he can make sure it's right
thank you just my luck, my friend agreed to do it on the phone just before he left and suggested i get the parts for him but this is the only part i was not sure about until now,and i would not know what to look for on ebay, but thanks for the posts anyway, regards Gerry
hi thank you ! i just looked at the box and the mains switch is on the left and there is an rcd on the right does this suggest that it is split. thank you could you please give me your opinion before i purchase anymore equipment. regards Gerry
Don't buy anything till your "sparky friend" gets back. It's very easy to get this sort of thing wrong and it'll take ten minutes in the wholesalers with his direction to get right
The consumer units and the spares are reasonable outlays,it would be prudent to curtail the urgency and wait for your spark to decide for you
Its possibly more expensive getting wrong parts that may not be returnable, than the cost of the spark to do the work i
Correct me if im wrong guys, but MEM are very similar to MK and eaton. MK mcb's and MK RCBO's will both very likely fit in the consumer unit. Recommend the MCB on the RCD side of the split load board as RCBO's take up space and getting a 6.0mm conductor or greater in could be tricky. (thinking of your sparky friend)
Mixing MCB's in different CU types is not recommended by any manufacturer. Only your "friendly" spark can advise you as to the cable, breaker, rcd, etc etc.
thank Ben i will show him this thread when he returns from Spain it might help him, i wanted to get the parts for him cos i live in the country about 300 miles from the town where you buy these things but it wont help if i get the wrong thing will it, i do find electrical installation interesting and would love to learn but getting a bit old now i think, regards Gerry
I had a similar request a few weeks ago and contacted Eaton directly and they sent this info back to me:
[FONT=&amp]The Memshield 2 range of mcb’s and the rcbo “pods” are still in full production, and can easily be ordered. As mentioned they retro-fit straight into the consumer unit you have.[/FONT]
The only issue is the cost of the Memshield 2 and rcbo pod! Quite expensive!
You will need a 40 amp RCBO.
How much do the pods go for? I work on a maintance contract currently and they over ordered on a job so I have a fair few knocking around
Gerry I'm going to sound brutal here and if I'm wrong I apologise in advance. I don't believe that this "sparky friend" of yours exists. I reckon you're a DIYer who wants to have a go at this himself and to a point I applaud you for being willing however, this is notifiable work, regardless of that, electricity is dangerous in untrained and unskilled hands.
Electricians are usually cheaper and less traumatic than funerals mate, I can't believe the advice you're getting.
Reply to mem 2000 AD consumer box, rcd for an 8.5 kw shower? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Just looking to see if anyone’s had a similar job or has any other ideas. Got a consumer unit to upgrade, the current one is fitted inside an...
Hi, I'm interested in a house built around the 1980's in Northern Ireland. I took a few photos of the consumer unit etc. which is situated in the...
I have a fairly recently installed consumer unit with an RCD, between it and the garden there is another, much older (25yrs?) RCB (big Wylex...
8.5K shower unit is wired to plastic box consumer unit to 30 amp cartridge fuse with no RCD It’s the original shower installed when the house was...
4K
The pic. is my friends consumer unit and what I can’t understand is: the left RCD is in tripped/off position yet he tells me the circuits 6,7,and...
