B
brizospark
Currently working on a large commercial renovation where the joiners are putting up new partition walls, double sheeted each side.
We have got the joiners to put dwangs in place for us to mount our socket back boxes (metal KO boxes 35mm)
As per the drawing we basically mounted the sockets back to back on the dwang and plan to drill through the dwang to link the sockets which are on the same circuit.
However, today the site agent came to see us and claimed that sockets should never be mounted back to back
Can anyone tell me the reason for this?
You will have to put intumescent gaskets in both the boxes as you have basically broken the fire barrier, I am sure screw fix sells them or TLC
screw fix part 55229
You should really, I use the steal dry lining boxes with the intumescent gasket already fitted from TLC in circumstances like that.
fair enough but would that not also be the case if the sockets were not back to back but say 150mm apart?
Yes if it is a fire barrier wall all electrical backboxes will require the putty/gasket inside, did on a job i done recently the project manager informed us of all fire barrier walls to seal up the bboxes
metal back boxes, back to back
Australia
brizospark,
brizospark,
