- May 13, 2019
- 6,312
- 1
- 10,286
- 13,648,391
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- Heavily Qualified Electrician / Teacher / Tutor - etc
house i am hoping to buy at the moment.We put the offer in on Friday, a good 10% less than the asking price…(considering it’s been on the market since September) but we haven’t heard back today…. So either;
1. The sellers are disgusted with the offer, and aren’t responding to such an insult. Or
2. They are seriously thinking about it.
Either way, it’s not a “no”
More thoughts on the plans, and I’m thinking this wall I want to remove is brick….. so structural engineer and an RSJ? Or, is it not actually holding anything up?
This space at the window was an outside store… so there has already been a brick wall removed, and RSJ added from the end of the chimney to the top wall…. (Marked grey on plan)
So if that wall (and now RSJ) was supporting joists… is it likely the other wall, which is running perpendicular, isn’t supporting anything? (The red bit)
I should have paid more attention to the floorboards.
Downstairs boards are running front to back… so joists left to right…. Do upstairs boards normally run the same way, or at right angles to the bottom floor?
I may be putting in a partition wall further forward from that position… to the other end of the chimney breast, just to give the kitchen more space… or I might leave it open.
Another thought is that where the outside store was will be a concrete floor…. Rather than floorboards elsewhere…. Then the thought of, could it have been an asbestos ceiling in there?
Home report hasn’t brought that up.
1st offer was 13% under the asking price.
they came back with a figure 9% under the asking price.
we have settled on that.
I might have pushed more but I have a wife that has started to make plans that now can not be upset!!
I dont think your original offer was insulting.
