Discuss POLL - Neutrals at switches in the Australia area at ElectriciansForums.net
RWJ
As the title suggests
In respect to the debate in this thread http://www.electriciansforums.net/e...electrical-forum/33420-neutrals-switches.html
I've decided to launch a poll to gage response from the forum.
GOOD / ACCEPTABLE - If you think Neutrals at switches is OK
BAD
/ UNACCEPTABLE- If you think Neutrals at switches is NOT OK / WRONG
UNDECIDED - If you have no preference or are fence sitting (like me)
The poll is timed for 7 days...... So get polling
GOOD - If you think Neutrals at switches is OK
BAD
Can you not use the word 'acceptable' rather than good?
I think it's acceptable but I wouldn't describe it as being 'good'
Good point IQ...
You can't change the poll once it's posted..... Apparently :(
I did toy with various levels of acceptability but opted for the straight Yes / No as it was becoming complicated.
Well I'm definately bad .........but there again ...........no definately bad ................but on the other hand it could .................NO I'm decided it's definately .....................yes I see your point
Oh drat I must be a fence sitter
Malc, and RWJ ur arses must be sore with all that fence sitting lol
same for me, perfectly acceptable if required although i wouldn't necessarily go out of my way to do it like that
Exactly... I think it's acceptable.. but is it good practise????? (RWJ's still fence sitting)
I think it should have been more a case of "where do you loop to - rose, switch or either?"
I do whatever depending on the circumstances - I wouldn't go out of my way to do either.
So on that basis my first vote is 'undecided', second vote 'OK', third vote 'not OK'.
Oh an AV man lololololololo
You also forgot the singles method! - Not meaning to open up any more worms!
You only have to look at some of the pictures provided in the other thread to see that its bad practise putting so many cables into such a small backbox. Using a switch as a junction box is terrible. The only people to have a switch that encorporates this is hager (as far as I know), so it can't be that common otherwise all the manufacturers would have this encorporated.
Put a deep enough box in and I can see nothing wrong with it.
However, if all you are doing is wiring pendants, then I can't really see the point in wiring to the switch first, however, if you want to keep the number of cables down at the light position (say for a fancy light) then its a good way to wire it.
Pros and Cons to both wiring method's, which is why an experienced sparky can decide which method is best before undertaking the wiring!
Just to throw a spanner in the works, who still wires a feed to a joint box in the roof space and wires all switches/lights from that???
Just to throw a spanner in the works, who still wires a feed to a joint box in the roof space and wires all switches/lights from that???[/QUOTE]
That was the way I was taught the old Octopus/spider method, and we had to fit the box with din rails, klippons and label each circuit
the spider and the loop-in to lights are handy for rewire's anyhow
but imo-it should be one 'method' throughout installation
they shouldn't be mixed
Wall lights or downlights would always loop in at the switch for me, pendants at the rose, bathrooms with timed fans etc at the isolator. Saying they shouldn't be mixed is potentially setting yourself up for more grief than you need in my opinion.
i would decide at start on one method
whichever-singles,loop to lites or switches ,spider
but imo 'best practice' is one method throughout
as much as possible anyway-there might be a few lights+switches done different where needed
DoBBY. Welcome back.
9 times out of 10 its loop in at the switch for me, much less hassle when doing fancy light fittings... and as already mentioned if many cables put a deeper box in... but thats just me!
Loop to switch cos putting those small light fittings up with 9+ wires in can be a right pain. pluse must better when doing down lights no messy box in voids
p+n loop to the switch all day long, why make things hard for yourself. any faults when you test through, theres no need to "get the steps out the van" as its all there in front of you at the switch. the only reason you wouldnt be able to fit a few extra cables into a backbox is if your using 16mm boxes, which i never use anyway so no problems.
anybody use 10 way lighting boxes on rewires and lighting alterations etc?
think the thread missed the eye of his needle. now that's got a point!
I should have put a forth option when I started the Poll.
1.Acceptable
2.Unacceptable
3.Undecided
4.Don't really care... and now bored with the whole thing
My point is that it's a pointless discussion.
There is nothing wrong with the practice of having neutrals at switches. Even the NICEIC endorse it. The mind boggles sometimes.
It would be pointless if there was only one point of view......as there are two points of view I dont see how it can be a pointless discussion.
Two points of view?
How the hell can there even be two points of view?
There is nothing wrong with neutrals at switches and that should be the end of it. There shouldn't be a second opinion to this amongst individuals that should know what they are doing.
Why would neutrals at a switch be any different to neutrals at a light or even a junction box? Hell maybe we shouldn't even be joining neutrals at consumer units eh?
The six that voted no, need to retrain or enter another profession.
At least 4 of the 'unacceptable' votes came from members with posts on this thread saying that they would take a neutral to the switch in some circumstances so the vote is not even as close as it seems lol!
With nearly a 1000 views on this thread alone and god knows how many views on the closed thread, and less than 100 that bothered to vote, i suggest you couldn't come to any such meaningful conclusion....
In fact most of the posters on both treads have been by the same people that just can't seem to get past it!! Does that mean that there really looking for reassurance, of there views?? Maybe that niggling doubt at the back of there mind forces them to come back time and time again just to make sure ...lol!!! Your all free to do whatever you want to do ....As it's been stated many many times now, that there is nothing in your BRB bible against the practice, ....so carry on in your own sweet way!!!
I'm sure yours is the only relevent view E54.
To ME, yes!! ...but i'm not you or any of the others here. I know what is and what isn't acceptable to myself!! You and the others have to decide for yourselves....
The forum's just full of 'bodger jobbers' and my beloved Arsenal will win the league...
Maybe not this year, but according to my 2 brothers and sister, and virtually the whole of one side of my family, next year for definite!!!
They have been Arsenal fans/supporters since they were out of nappies. ...Maybe even before!! lol!!!
As for the wanna be sarcasm, ....irrelevance rules!!!
Reply to POLL - Neutrals at switches in the Australia area at ElectriciansForums.net
Firstly, I hope it is ok to discuss the wiring of speakers here. TBH my ignorance in all things electrical knows no bounds, and I am guessing it...
Good afternoon guys. Recently had to make an impulse generator purchase. Looking for some guidance to make my generator use both more flexible and...
Ok Hello all and thanks for having me. I need some advice and joined this forum hoping to be pointed in the right direction. First off I am not...
4K
Hi guys, I have come across two problems today well acutely three so I will list them first.. 1st Testing a 4mm radial circuit today or so I...
7K
Engineer54
E
