Discuss Protecting DNO equipment in the UK Electrical Forum area at ElectriciansForums.net
A House of Multiple Occupation (HMO) officer inspecting a HMO for temporary accommodation has advised tenants might be tempted to play with DNO equipment as it's not in a locked cupboard.
I'd be interested in your thoughts, my view is nothing to do with me, DNO install this and deem it to be safe, therefore I should not touch anything.
HMO officer suggesting locked cupboard, but surly you can't put a lock on DNO equipment, they need access?
Depends on the nature of the tenants, the officer may be aware of this hence his recommendation. I have worked in plenty of these places and seen all walks of life in them. Most are happy to roll with life but a few just want to kick to pieces anything they have put in front of them.
As the meter has only been installed for 4 months someone should contact the energy supplier to put some clips on the cutout - meter tails.
If it's going to be boxed in it needs to have a triangle meter lock on it or the meter reader won't be able to get it (unless they've scrapped the compulsory 2 year reading/check as was being proposed recently).
If it's secured with a triange meter lock then any fool could buy one, open the box, by pass the meter and close the box and no-one would know.
If it's left uncovered everyone can see it.
Reply to Protecting DNO equipment in the UK Electrical Forum area at ElectriciansForums.net
Having a bit of a mare at the moment with a small 2 story HMO (6 single rooms with shared kitchen) which was fitted relatively recently (2016 or...
Hi Have done some additions to an existing multibuilding non domestic site. I noticed no SPD on the mains intake side, they are in a reasonably...
I installed outdoor lighting and outlets. I finished this past year. I passed my inspection on April 2022. I was so pleased, BUT now the circuit...
Is there a room in professional PAT testing for a business model other than 'per unit'? I ask because I've been giving this some thought. I've...
9K
T
So asked to attend tripping RCD whenever cooker is plugged in. That bit was very simple, gas cooker with igniter plugged into extension. Soaked...
The Ghost
T
