Discuss Removing pv panels in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
dal11851
Hi, hopefully someone can help me, I'm trying to find out if its possible to remove the 4kw system I had fitted on my bungalow to have the roof re-tiled then put back on. Iv also been looking at the idea of flushing the panels into the roof using the renusole kit.
If I was to have this work done would I need to inform anyone and would it have any affect on my FIT payments. Also would this work need to be carried out by the original installer or any pv installer or could me as I'm a sparky and my roofer do it.
( before anyone says should of changed the tiles first I didn't enough before they dropped the FIT rate )
cheers Dal
Can change them no problem. I would check with installer wether it will effect there workmanship warranty that they provide, as for dropping panels into roof, in my humble opinion it's a bad move the more hotter a panel becomes the less efficient it becomes, stick them on roof and allow a nice flow of air to increase kwh ! Plus I don't trust in roof heard of a few leaks!
Reply to Removing pv panels in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
My best mate has been medically retired from the prison service at the young age of 52 and has time on his hands :D He's looking at a 'plug in'...
I am a Napit registered electrician and want to get into Solar PV and battery storage. I have boot camp booked in April but am not hearing good...
Hi again. Following my recent zero-Riso issue (unresolved) and also because my system has, in any case, been prone for a good while to the odd...
Hello fellow professionals, I'm currently facing a challenging scenario that involves the integration of solar photovoltaic (PV) systems on roofs...
I am interested in having a home generator that would provide power to my home when the power is out during hurricane season, etc. I have 2...
