Discuss Resistors in Parallel Help in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
M
Markrobert30
Hi All first post.
I'm currently doing a Pre Entry in Electrical Engineering and really enjoying it so far.
My question is i'm finding the Resistors in Parallel a bit tricky see below.
The question asks me to determine the values of V,I2,I3 and R
Suppose i'm more confused in whats best to workout first
I've attached a Jpeg of it so you can see it i've written in the answers as they were on the sheet but if anyone could help i'd be really grateful.
Image below also.
Mark
This isn't really working out resistance in parallel more a case of ohms law.
First thing I would work out is V using the value of R1 and the current across it. V = I x R,
V = 10 x 5 so V = 50.
Then knowing the voltage you can work out the current I2 using I = V / R, I = 50 / 10 so I2 = 5A.
Lastly for I3 you know you had 40A to start with and you have 10A across R1 and 5A across R2 leaving you 25A across R3. Then use R = V / I, R = 50 / 25 so R = 2 ohms.
Hope this helps.
Hope this helps.
Hey Sintra
That's perfect thank you think i was just getting myself confused with what to workout first. But your workings make it look so easy.
Mark
Hope this helps.
<pedant> Current flows through a resistor, not across it eg "you have 10A flowing through R1." You have a voltage across summat, eg "you have 50V across R3, and you know there's 25A flowing through it, so R3 = V / I = 50 / 25 = 2 Ohms." </pedant>
Other than that, absolutely spot on :)
Reply to Resistors in Parallel Help in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
A bit of a mini essay but these questions have been building up in my mind over the last weeks and months as I've been studying and volunteering...
Hi, I would genuinely appreciate some guidance. I am currently completing training for my City & Guilds 2391-52 practical, and as there is some...
Hi Everyone, New to the forum so please excuse any stupid questions which may come below. Sorry if this is long winded but I want to give a good...
8K
Hi guys I'm a recently qualified C&G Level 2. I have my 18th edition on the way in the next few weeks. I have a CCNSG AND IPAF 3a/b card, happy...
