Discuss secondary consumer unit and bonding in the UK Electrical Forum area at ElectriciansForums.net
hi all
I have been asked to change a consumer unit in a house. Most of the house is covered by a new consumer unit (17th ed.) and all the bonding to gas and water is covered by this. The consumer unit i am changing covers the electrics in an old extension that consists of 2 bedrooms and a living room. The only circuits on it are 1 ring for sockets, 1 radial for sockets and a light circuit. My question is do i have to ensure that the gas and water bonding are covered by this CU also, or is the fact that it's got a 16mm main bond back to the MET enough?
thanks
neil
How is the second CU (DB2) that you are replacing connected to the "juice".
Is it run from an MCB in the main consumer unit
or
Has it got its own set of tails from the incomer (eg henley block)
or
does it run from a separate switch fuse?
What type/size of cables connect to the main switch on DB2
Reply to secondary consumer unit and bonding in the UK Electrical Forum area at ElectriciansForums.net
TNC-S main supply with 16mm swa supplying garage consumer unit from main consumer unit in house, then 4mm swa supplying pond equipment through...
Just a thought guys in terms of RCBO’s and supplementary bonding. Obviously supplementary bonding isn’t required as long as a 17th / 18th...
Hi I have a job where customer has two families one families lives upstairs and one family will live downstairs. As the property is going through...
Hi All, looking for some assistance on this as finding different information wherever i look. We have a garage external to the house, which we...
4K
Hi, I'm interested in a house built around the 1980's in Northern Ireland. I took a few photos of the consumer unit etc. which is situated in the...
