Discuss Small 50x50 adaptable box in the UK Electrical Forum area at ElectriciansForums.net
Hi All
any suggestions for a small adaptable box with dims approx 50 w x 50 deep (length not really an issue), the Wiska 206 would be ideal (85mmx49mmx51mm) however I need to get an earth Banjo on there as it is swa cable and I don't think I will get one on on the wiska with the pre threaded holes (not enough room on the internal gland thread, any suggestions appreciated
use a wiska box with wiska's own gland plate.
Thanks Guys, don't think they do the earth plate for the smallest 50x50x85 box. I could use a piranha earth nut but the glands i have the internal thread isn't long enough to pass the plastic thread of the Wiska
If the wiska had flat sides instead of the integral thread, i could get banjo or Piranha on inside, just can't find one, either plastic or metal, that is 50w x 50deep or thereabouts
https://www.NoLinkingToThis/p/schne...box-with-knockouts-grey-65-x-65-x-45mm/63295.
or:
https://www.NoLinkingToThis/p/schne...-box-with-knockouts-grey-65-x-65-x-45mm/63295
pick the one with the cable entries you require.
even a plain small galv. box.
there are no problems, only solutions.
also, you can use a long thread bush. insert from inside then screw SWA gland to bush.
soz. you'd need a galv.coupler as well.
Reply to Small 50x50 adaptable box in the UK Electrical Forum area at ElectriciansForums.net
For various reasons out of my control, we have wound up in a situation where we have 1.5mm SWA cables buried in these pillars and exiting out of...
7K
I'm working on a system that has been installed incorrectly. It's a 3ph Hager board with 8 swa cables glanded into the bottom entry panel. The...
I’m looking to fix a previous install. After having some rendering I have a feed that’s in 10mm T&E and I’m looking to replace the conduit. The...
6K
Hi all. I have a job of wiring 3 lights on a tarmac drive with a block border. The customer is set on the ksr calanda bollard. Problem with it is...
I bought 20 boxes for an outdoor project. I paint my parts before I install them so they look nicer than trying to paint them in place. That said...
