Discuss So wrong but yet so right in the Canada area at ElectriciansForums.net
H
homesafe
I installed a security alarm on sunday,after buying everything i thought i needed on Friday i turned up at the job to find the alarm cable i had on the van was actually 3 pair phone cable,What was i to do,i had just got up at 730 on a Sunday,so had the customer,I needed some cash for my holiday next week,So i used it.It is miles easier to work with because it is a single core and quicker to connect,
U can slag me off now if u want!:)
hi
Im not sure if it matters ,is there an "approved" cable for alarms?
as long as it can carry the current,which is probably not much,i think its a good way of doing it;)
The problem comes when you're the person servicing the alarm every year. Solid core telephone cable snaps very easily during maintenance and when using screwed connections. IIRC, EN50131 makes note of using only cable which complies to the relevant standard (i.e. BS4737 type cable)
Reply to So wrong but yet so right in the Canada area at ElectriciansForums.net
I'm practising EICRs on friendly locations as I'm still in training - technically done my 2391-52 but frankly need loads more practise. I've just...
I have a baffling problem with a newly-installed PIR floodlight and I'd like advice from the forum as to whether it's defective (and should be...
The symptoms its been having to start with was the fuel gage only working sometimes and when i play music from my phone when a loud song came on...
This is quite lengthy so get comfy... I had a bizarre call out relating to a job I attended about five years ago. The situation was they were...
