Discuss Sockets under Sink ? in the Australia area at ElectriciansForums.net
L
Lioned
Most new kitchens you seem to have no option but to install sockets (for wash machine/dish washer etc) under the sink in the base unit.
I do not believe there is any reg's restricting this but some kitchen fitters i come across still seem to think it is taboo (though they do it anyway).
Am i right,that as long as circuit is protected by rcd/rcbo there is not a problem ?
I would always fit a fused spur above the counter feeding down to a single socket beneath.
i wouldn't. 2 13A fuses-no discrimination. i fit 20A D/P isolator. undedr sink may not be against a specific reg. but bad practice all the same.
Not something i'd do if it could be avoided but there's no space anywhere else.
Also quite common offcourse to have waste disposal under sink so you'd have to have connection unit for that somewhere ?
I used a totally unconventional method to avoid discrimination problems, and to get away from having to disconnect cables every time i needed to pull out a built-in appliance. All my appliances are controlled by FCUs above the worktop by the way....
I used MK single Yank outlets and plug tops, ...lol!! I'm sure they'll be those here, that would disagree with my unconventional method of localised disconnection, but it's electrically safe, and solves a problem. I did look for none standard British outlets and plug tops without fuses, even considered the old BS 15A set-up, but couldn't find any in Cyprus. Anyway i had these Yank outlets handy, that were ear marked for a completly different use, that never transpired...
I'm sure there are British none standard pin arrangement outlets with non fused plug tops, that gets over the inconveniences of supplying kitchen cabinet built in appliances, just couldn't find any available in Cyprus....
In 30 yrs I've yet to see a problem directly related to a socket being located under a sink............as long as it is sited with care....ie not directly under the waste!!....I cant see any problem
Personally i would rather see a socket under a sink and be able to remove the plug even better if FCU above, seen so many installs with neither just tapped connections Etc and totally inaccessible
I agree completely, it's up there with the 'RCD main switch and the old lady tumbling down the stairs in the dark' scenario...
I understand the 'discrimination' issue,though think it a bit dubious between a plug top and local fcu which are located so close together.I would be suprised if it were to be considered an issue on inspection.
Sockets under the sink or in an adjacent cupboard every time.
Why not behind the appliance it's supplying, that's where all mine are in my house??
What i have no time for is cooker points buried in cabinets behind myriads of pots and pans, or tins of this and that!! Or sockets that that should be above the worktop, but aren't because a householder doesn't want to see FCU's or sockets in there over expensive tile work. ....Most if not all, live to regret that daft idea. A kitchen is a functional work space, not a fashion accessory/statement for others to admire....
Tbh the appliances are more likely in a new install to take the rcd out than the fuse in the plug / fcu as most faults are going to b L-e N-e
So you'll be quite happy pulling out say, a heavy washing machine, or an oven, just to replace a plug top fuse?? .....Rather you than me!! lol!!!
Try telling that to lady muck who's persuaded hubby to cough for a new bespoke.......:2guns:
A kitchen is a functional work space, not a fashion accessory/statement for others to admire....[/QUOTE]
Thats a fair comment in a standard 2 up 2 down house, but it is not always like that. I do a lot of £3-4 million + houses with bespoke kitchens costing in excess of £100,000. I would not have the gaul to stand there and tell the architect, customer, site manager that there kitchen is not a fashion item. In these kitchens they barely have a socket above worktop because it will spoil there fashionable 'clean lines'. And I cant say I disagree with them. They all have ornate glass splash backs and im not surprised they dont want banks of fcus on show. I can fit as many as 10 in a kitchen and it would look dreadful above the work top. In my eyes I am not following bad practice, Im not going against the regs and I am keeping the customer happy.
The electrical business has always been about aesthetics, functionality and safety, it's finding the correct balance between the first 2 and that changes from client to client.
Don't confuse a Rich Man's kitchen that will rarely if never be used as an every day functional kitchen, unlike your standard Mr averages 3 bed house....
I've had plenty of discussions with architects, on kitchens etc, and believe it or not, some can actually see and act on the points i make to them. Most Arch's are hairy fairies with their heads up in the clouds, that haven't got a dammed clue about living in there designs, let alone in the real world!!!
(quote)I've had plenty of discussions with architects, on kitchens etc, and believe it or not, some can actually see and act on the points i make to them. Most Arch's are hairy fairies with their heads up in the clouds, that haven't got a dammed clue about living in there designs, let alone in the real world!!! (quote)
lol, tell me about it. I am currently wiring a £4 million build 5 bed house, and I am sure that from an architects point of view it is a great design. But they sacrifice any functionality so that they can achieve their vision. for example, the whole house is an arc design, so beds 2 and 3 (in the middle of the arc) are so cramped I couldnt even fit the cbus light switches in the ensuite. i dont know about you but if I was paying £4 million to build a house I would be a bit peived if I burnt my face on the towel rail everytime I was dropping the kids of to school if you know what I mean!! just remembered as well in the planning stages, the architect and client suggested to my boss that in the lounge they should have just 1 floor socket underneath the sofa for a lamp!!! I dont know how there brains operate sometimes.
Thing is i wouldnt put a socket behind an appliance,thats the whole point of putting them under the sink were you can get to them.Most appliances there is not enough space behind them (if they are integrated) so you just cant do it.
Well i've never had socket outlets placed anywhere else on any of my projects, be they commercial or domestic type kitchens or in my own homes. And no i've never seen or had problems with placement space either... All have been installed into the fabric of the building too, not on the sides of kitchen cabinets...
I dont like sockets or isolators or any outlets inside kitchen cupboards and the like
I know a case can be argued for them,but it doesn't sit right with my own thinking and probably never will
Cant see where else you can put them tbh.In a fitted kitchen you have to accommodate.
Cooker connection unit
Hob ignition (socket)
Fridge /freezer (possibly seperate circuit)
Dishwasher
Washing machine
Under cupboard lights
Possibly plynth lights now getting popular
Extract hood
Possibly waste disposal
I challenge anyone to install a fitted kitchen and not end up with most of these in cupboards ?
You could just as much argue a case for not having sockets in a garage as sooner or later the roof will leak.
I was taught FCUs above worktop to low level or high level sockets or flex oultets for extractor hoods etc and low level sockets behind cooker etc and washers
but i see no problem due to necessity and no other way if installing in a fixed cupboard apart from what if someone decides to rip kitchen out and dont notice a Fused spur or cooker DP switch and all the wring comes with it also have seen some where chopped in above worktop and when underneath cable just slung behind cupbaords dog rough in my veiw looks like a washing line as does my brothers kitchen which cost him a fortune
the transformers and wiring for the selv pelmet lighting is slung on top of the amarican style freezer which slides into a intergrated unit
and a double high level for freezer with 2 T/e dropping down behind worktops
guess who is going to sort this mess out
for fridge freezers and chest freezers would you install fcu or just wire sockets into the kitchen ring
I would not use fcu for a fridge/freezer.Just a single 'unswitched' socket outlet.If i had the opportunity i'd run a seperate circuit for the freezer.
Reply to Sockets under Sink ? in the Australia area at ElectriciansForums.net
Hi, I have lifetime experience (50+ years) in United States with basic knowledge of split phase 120/240 volts replacing wall switches and...
Hi Guys, I'm having trouble diagnosing a fault on a customers downstairs socket ring, which only ever trips when the washing machine is used. The...
Morning All I recently completed my first re wire and board change, (with help from the owner who is a gas fitter and plumper, who works with my...
Hi everyone, I have recently had an extension built with a new Utility room. The electrician has put the sockets for the washing machine and...
5K
