Discuss Vehicle Tyre Compressor wired direct from battery to pump. Wire overheats. in the Auto Electrician Forum area at ElectriciansForums.net
B
BML
I just bought a 12 volt tyre compressor and the instructions say connect it directly from the battery. The pump worked well but when I disconnected it the wires were very hot. Does this mean that the wire is not sufficiently robust?
Yes really.
The wires may well get quite warm but should not get hot.i.e. hotter than you can hold for a while.
If they are getting hot then they are taking more current than they can readily handle and if the compressor is left running they may start to melt.
The supply cables should probably be of a thicker diameter or they maybe only planned for very short term use (not a good design)
or a poor connection to the battery terminal/s crearting a high resistance.also, as Richard said, these compressors are only rated for short term use. some even say to disconnect after a minute or 2 and allow to cool.
^ As above,the instructions,probably an amusing translation,will state a "duty cycle". This may be 2 mins on,8 mins off. In practical terms,this is usually ignored,as everybody wants their tyre pumped up...not HALF pumped up...
With judicial use,warm,soft cables,are a regular issue.
I have a similar compressor,an RAC 900,i think,which has been in use for 7 or 8 years,now. I tweeked the relief valve,to allow it to reach 95 psi,my trailer tyres requiring this.
On occasion,i have had to drape a wet cloth on the compressor head,but it still functions :yesnod:
Reply to Vehicle Tyre Compressor wired direct from battery to pump. Wire overheats. in the Auto Electrician Forum area at ElectriciansForums.net
I've always thought I was quite good a wiring heating systems, I can do Y plan, S plan, UFH set ups, "normal" thermal stores etc, you name it and...
I have an existing but unused 50A disconnect on the side of the house. It had been connected to an AC unit that got replaced. It has just 3...
Well....wiring in a 1750s thatched cottage attic, not wiring made from thatch 🤪 One we have been letting for over 20 years (as well as enjoying...
4K
Good evening, I have recently moved into a new home and I am having problems with the MCB/RCD tripping (Mem M6 Type 3 - 30mA). It intermittently...
Hi everyone. The owner of the business I work for along with myself have created a DIY inverter setup that is giving us some issues. We bought...
